you can still see the hone marks on the bores, the rings have barely worn
hard to believe piston pins this thin could withstand 1200hp and years of punishment
still only using 10mm head studs. 100's of passes @ 30psi and they have done a fantastic job. the torque was checked a year ago, they hadn't budged
cams and cam caps didn't fair too bad, that was the worst of them
only removed a few rods so far, crank looks pristine
shims look ok, not too much damage or wear
that looked to be the worst of them
bearing has seen better days, but, still not bad considering
not much meat there, has a -16cc dish. think was something like .150''-.180'' crown
mains didn't look too bad
super tough block
the plans are a whole bottom end freshen up with new rods and pistons. although they are still in good nick, should be replaced. we are replacing the 8:1 Ross Pistons with a 10.5:1 CP Piston and sticking with Argo for the rods, hopefully the bump in comp, we might see a 30-50hp increase in HP. the block is being torque plate honed and we have drilled it out for bigger headstuds, although we haven't seen any major issues with the heads lifting, we are still going to change them out. in the last 6 months if we ran the car without cooling it enough, the heads would lift a little, pushing a little water out the radiator, before then it was never an issue, after 3.5 years of copping the abuse, the studs would have got a little weak.
	super tough block
		 I have a mate who might be able to x-ray the parts for me
