Lol, guys, where has this thread gone to in the background?
You guys are thinking way past my transmission choice. I know I haven't explained the plans for the Datsun build (to be explained in a new dedicated thread in the future), but the plan is a budget rat-rod-ish short track/street hoon machine. I had been watching craigslist for any 5 or 6 speed that could handle about 250 ft/lbs ok for a while, and when this little guy poped up for an awesome price, I just grabbed it. I knew the gearing was short, but as Stevie said, a tall rear gear can make more use of it. That being said, nothing is more "shifty" than my 2013 Volkwagen GTI 6 speed. Normal pattern for me to drive in is 1st, second, (sometimes 3rd) 4th, 6th. So many useless gears!
Crappy cell phone pic, but glad to report the car is with me in the Northern Chicago suburbs (where I work) and running great. Cooling has been fixed and is very reliably relaxing (will explain in a much needed update later), and I have been spending some time just simply enjoying cruising the car around. It's been almost over 3 years since iv'e had it on the road, but the response from onlookers has been very humbling. Nearly every place I stop, people want to know more about it. Gas stations, stop lights, even when i'm cruising down a four lane. People generally just seemed to be confused by the car, because they don't know what it is, but the puzzling exhaust note seems to definitely grab most people's attention.
I cant thank all you guys enough for the help and support through the years, I couldn't have done it without you all.
The only small things I would have to comment on is that:
1. There seems to be random times when there is a weirdly consistent stream of slight smoke/vapor coming from my catch can outlet, mainly at idle. Nothing too alarming, but it is weird. I didn't notice this at all on my turbo 6 cylinder car which I knew had some worn rings, but this motor seems sealed up very tight by the total lack of smoke from the tail pipe when I wail on it. Perhaps check valves or a vacuum draw from the pre-turbo pipe are in order? I was hoping to keep the crank vent system completely separate from pre turbo pipe as i didn't want to accumulate any oil/sludge on my turbo impeller, but I'm thinking I might rather deal with cleaning that a few times a year versus smelling the catch can vent to atmosphere.
2. It would seem that my darn spark plug tube seals are leaking again on the driver valve cover gasket, but not alot. Just enough to drip down every once in a while on the hot exhaust manifold and make some nice smells for me. I would say it has more of a tendency to leak when I really beat on the car, which again may be a crankcase pressurizing issue? This is a salvage motor I haven't opened up internally, so I was suspecting it more than likely would have a little blow by. I would certainly like to stop the oil leak if at all possible though, as hot oil dripping on very hot exhaust can be worrying probability for a oil flare up/fire.
I will try to grab good photos in interesting areas this week, and maybe more video footage. Thanks again everyone, and be on the lookout for another big update soon to explain some of this things i have finished on the car to this point.
-Mike
