Thanks, Morris. I think the SAFC is tuned along the RPM curve, which means it's tuned along with the boost as well. More RPM, more boost. So if I tune it at Stochoemetric point at cruising & idle, then I should be ok. I'll look into the SAFC as you said.
For the removal of the swaybar, you're still the winner. I'm also thinking about flatting the dual 2" downpipes to 1" so they'll fit along the swaybar & give better ground clearance. The hard part is flattening them at the angles without crushing them. Or I'll just run 2 dual 1.5" pipes as planned.
