True, in stock form (even an unopened) 1UZ UCF10 will show a torque peak around 4500rpm, and rapidly dropping afterwards...this has been proven by dyno sheets many times. In supercharged applications you have a different (more flowing?) manifold design.....so, my guess is that the cams might, in both SC en turbo setups, be the limiting factor.. . there is a lot of talk on this site about the standard lower manifold runners restricting airflow above 5000rpm . . .
In retrospective, I think we should have changed the cams first before making a new manifold...
Just look at Majoola, RATS, etc...once you get all the limiting factors out and make the adjustments that are needed (valve springs etc etc..) you get a 4.0 V8 race engine capable of 1000+ hp....RATS made 1005hp on 1,6bar from a (big) SC....
http://rats.no/omega_tg.html
Anyone has a dyno sheet with stock manifold with upgraded cams ?...
But the are so many factors...so Doc, lets see what power you can make from your setup...
