The plan
Thanks again for all of your time and interest. I really appreciate it. There appears to be quite a variance in opinion, and experience, as to the strength, and horsepower limits, of the standard (large rod) 1UZ bottom end. Some compliment their own good tuning for the reliability of their motors, while others claim bad luck for broken parts on well tuned 1UZs. And there have been some broken parts because of mistakes. I believe all groups. So, now I have to make a decision. I do not have unlimited funds for an 'ultimate strength' combination, but I have some petty cash. Here is what I am going to do now: I have found a good rebuild-able 2UZ bottom end (in "up country" Thailand). I will use my current intake, supercharger, heads (it is good, but needs two new valves, which I have), deep oil pan, camshafts/springs, and head studs with this 2UZ short block. Amazingly, I found and purchased a set of Lextreme steel rods and Calico bearings here in Bangkok. I will check (and correct, if needed) the 2UZ crankshaft and bore/hone the block .030 over (292cu.in), get ARP main studs, and order the appropriate forged pistons in a 10.5 or 11.0 compression - because I have taken the humps out of the combustion chambers and have only 5-8 pounds of boost on race gas. I will order another set of 1.3 Cometic steel head gaskets (I have sold the 1UZ set already). I was already at 85% duty cycle on my 565cc injectors with the dry NOS, so I will also get new 1000cc injectors (for MORE NOS!). For future use, I am also negotiating for one of those high flowing New Zealand single plane high rise manifolds converted to EFI . . . . . SO LOOK OUT! Wish me luck! I hope you haven't run out of it yet!
