Dyno Day . . .  Oh Well . . .
Well . . . the new motor combination finally got to see its day on  the dyno . . . actually two days.  There were a couple of issues that  first delayed the dyno pull, and another that stopped it.  Of course the  water pump chose this moment to start leaking.  A  runner was sent to  fetch a new one . . .  and it was installed four hours later. Then, when we got it up and running and a map was gradually being put  into the ECU, the dyno computer would shut down for no reason as soon  as we started to make real noise.  It was determined that the  combination of RF interference and too much noise from the open headers were  playing hell with the  computer.  We devised  some shields and,  because we were at the AVO (Yeah Subaru!) manufacturing facility, they  made up some large 3" pipes with nice stainless steel mufflers for the  dyno.  This worked up to a point, but the dyno computer still died.   More shielding was added around the dyno computer, and a
human shield  was added (me!). This worked . . . . but then the car would not,  absolutely not, run up above 4800rpm. All the usual suspects were  checked (fuel pressure, spark, etc., etc.). It was like the throttle was  being held at that rpm (it wasn't).  The fuel pressure and AFR were  right, and it was not missing, popping or banging. We were all  mystified.  Then we tested a "free rev" with the trans in Park . .  it  sounded like it was up against a soft rev limiter at 5100rpm. Oh well.  Time to go  back to the shop and move the CDI the hell away from everything else,  shield it, and separate all high RF wires from anything.  Theory number  two was that perhaps one, or both, of the intake cams were put in too  far in advance . . . a telltale sign being the 663 ft. lbs. of torque it  generated at 4200rpm.  Not too bad, really, from a 242 cu.in. (4.0L)  motor on race gas. We'll sort it out and be back on the dyno in a couple  of weeks.  I am disappointed . . . but we learned a thing or two.
The YouTube clip is here:
http://www.youtube.com/watch?v=88x8r2a2R5s
The Dyno Day Debacle started with a water pump replacement.
The AVO guys made a nice pipe and muffler set-up to keep the race from vibrating the dyno computer into the "OFF" position.
I  complained to the AVO Mangaing Director that this exhaust system would  make my car very difficcult to park at the shopping mall.
El race truck con
twice pipes.
