hey all
Some time spend in the garage again this week, a bunch of little things taken care of, and a few big problems solved.
I have finaly got hold of some tubes that take the laminova cores, with a little help from an englishman in australia they even got over here in holland.
here´s one with the intercooler core inside, the fit is very tight as it´s supposed, the gap inbetween the tube wall and the fins is less than 0.04mm took a year searching but I knew this ID tube would be availeble somewhere. it's listed as a scaffold tube......
also the I decided on the route of the belt driving the chargers and the alternator and I had to make a piece on the lathe that would carry an extra support pulley, and a few small alloy spacers for the left hand SC mount and the alternator, having a lathe is very nice when making all pulleys line up, measure up what you need, turn and it fits right away
here's 2 simple spacers
the support pulley carrier took al little more measuring, the carrier also protudes into a 12mm hole drilled in the engine bracket, so the pulley is supported buy the carier and the bolt is used to tighten it up. it should be strong enough, the steps on the outer end are made so that the bearing inside the pulley fits tight on the carier. the thread in the head was M10 x 1.25 so a piece of threaded rod was bought (
expensive stuff....) got the bolts for free though.
here the pully is fitted
I also had to make a new alternator bracket, the alt don't need to swivel because the 1uz has a very clever pulley tensioner somewhere else, so it can be mounted solid.
the alt upper mount is bolted down into the engine it self the lower bracket is only there to stop it from turning on the upper bolt hole.
once that was done I could finaly measure up the length of the new belt that I need, I did that with the tensioner held down with a "spanband"(don't know in english) and a piece of rope, it measures 261cm with tensioner held down and 266cm with tensioner slackend. that's about 103" of belt to order from gates
gates PK61025 should fit perfect.
the route with tensioner held down
god forbid the 14 spanner comes of the tensioner pulley whoops, i'd have to dig it out of the concrete ceiling methinks haha
the allingment of the pulley's is about spot on, I can measure a 0.2mm run out at on the outer edge of the right hand SC pulley using the laser,(the corner pulley on the crank side reads 0.0)
I think that's about as close as I can get it using only a hacksaw, 3euro laser pointer (stripe) and digital calipers and a second hand 18yo cebora mig welder :crazy:
so on with the intake manifold and intercoolers.........
hmm Question: I need to weld alloy now.....
time to buy a tig welder?
or have someone do it for me?
it must be neat because it's the first thing you'll see when to bonnet opens.
Grtz Thomas
