turboandrew
I forgot to ask about air fuel ratios. Too rich can cause a big drop in HP, and would help explain all that fuel you are using. Did you happen to log air-fuel ratios?
anyone know the average life span of a standard reservoir of methanol? Is it like gas, do you have to fill up at every fillup? just curious because i would not mind the fill, and even when out it would not hurt anything, just less efficiency until next fillup? I figure 7psi is healthy for a daily driver but add the IC and meth I could 'squeeze" more power from my 7psi?
Just curious but why is there such a large gap between hp and tq at 6900rpm? 498hp and 379tq? wouldn't our engine produce more tq than hp, especially w/ roots? Or is it a dyno attribute?
Not much to report ATM. Dennis has been up to his eyeballs with other work, but the plan is to sort out the difference in compression from bank to bank, put a cogged belt system to drive the supercharger, fabricate some dyno headers, then have another go on the dyno.
We're also preparing a 2nd 1UZ, which will have a different set of cams and should put out some some interesting numbers. This one will also have 12mm head studs, piston squirters, Lextreme rods, Ross 8.75:1 pistons, etc.
I'm tempted to keep one motor supercharged, and build the other up as a twin turbo. Except for the FMIC piping, the car won't know or care whether it's a turbo motor or a supercharged motor, as long as the intake, fuel, radiator, and exhaust pipe(s) connect in the same place.
I honestly think a turbo motor might be a little easier on the drivetrain than a supercharged motor, as it won't have such a fat torque curve. 425 ftlbs of supercharged torque from the get-go might be too much for even the Supra's mighty 6spd, whereas the turbo motor's torque should come on more linearly with boost and RPM.
We're shooting for another dyno session before Christmas.
Would be nice to see what the final figures are when done. Would be nice to compare results on the blown engines
My engine is ready (after a full rebuild and mods) but just had some last minute changes to the blower drive system before fitting to car.
Thanks for the insight into what you've got planned. Very exciting stuff!
It is interesting and fun stuff exploring what can be done with these little V8's. Just a tad expensive though....
My biggest fear!
I would not worry about it too much. There was just a Supra in TX who has done 242 MPH in a -standing- mile race (the record at this track by a big margin). That Supra is producing over 1500 rwhp and easily over 1000 rwtq. Yes, 1000 ft/lbs of torque, on a stock V160 getrag transmission. There are not many things harder on a drive-train than top speed runs.
