So I've been kicking around the idea of twincharging this motor. I'm also thinking of taking a somewhat different approach to it, and am open to your comments and suggestions.
Here's my idea: I'd have twin turbos with a FMIC, and they would blow into my existing twinscrew supercharger. The turbos would be sized with big A/R ratios, so they wouldn't produce any real boost below, say 3500 rpm. At low rpm, I'd be boosting solely with the supercharger, and when the turbos came on boost, I'd gradually open the supercharger's bypass valve to unload it, and let the turbos take over. At that point the turbo's would be blowing through the supercharger, and through the open bypass valve, and the supercharger would simply be freewheeling.
This would have the added benefit of reducing the supercharger's parasitic load at the top end, which should add an additional 60-80 HP to the flywheel.
So although on the surface, it would look like a two stage system, in reality it would only be a single stage of compression, with two different forced induction systems working in their happiest regions.
I don't need or want the crazy boost pressures that two stages of compression would produce, but I do think this system might be able to combine the strengths of both technologies.
The trick, I think, would be keeping the boost pressure under control, while the turbos are coming up, because they wouldn't be pressurising the engine directly, but would be pressurising the intake of the supercharger, and it, in turn would be adding its contribution and compound pressurising the engine. With judicious control of the SC bypass valve, hopefully it could be a smooth process.
Comments?
