John, Just left you a voice mail.
Some things are comming to mind that suggest that you are PUMPING a bunch of the air and fuel out the exhaust.
Your injectors should NOT be out of flow at 500hp and you as noted are adding additional fuel with the methanol.
The exhaust blowing off points to a BUNCH of energy release in the exhaust instead of flowing the burned A/F that has given much to the crankshaft.
Two 2.5" pipes have nearly 9 sq/in of INTERNAL pipe area. A single 3.0" has about 6.5 sq/in and many have made 700rwhp on a single 3" pipe. You are NOT out of exhaust capacity for your ENGINES current output but rather for the TOTAL energy capacity and exhaust system demands of the charge burning in the exhaust instead of in the cylinder where it can make power.
So, IMO you have WAY more power in the current combo. Almost worth putting a STOCK 1uzfe under than blower to baseline your FI combo.
Since no pictures yet let me post one off my crappy cellphone I took 2 days ago of your engine on the dyno
