HarperRacingBangkok
My Bad!
Well, every project needs a major miscalculation, and I have had mine.
Nobody to blame but myself . . . . sort of. My builder/shop guys 'could have' caught it, but I'm the guy who supplied what were suppose to be the "right" parts. The part in question is the 1UZ bell housing which is "suppose to" be able to mount the 1JZ automatic transmission "perfectly". Well, the mounting surfaces and bolt pattern of the 1UZ bell housing are identical to the 1JZ, the only problem is that they are not the same DEPTH! No Good! Of course this means that the splines of the trans input shaft do not engage the torque converter or ride in the pilot bushing. No good! I made various inquires on the Internet with experts, visited a ton of sites, and even called up legitimate, big name experts on the subject at reputable transmission shops and was assured by all that the 1UZ bell housing would mate the 1JZ automatic trans. Nope. I am guessing that there are more than one 1UZ bell and more than one 1JZ auto box involved here and that I have the novel combination. My fault was not measuring (let that be a lesson to us all!) or simply placing the bell housing side by side.
Yes Virginia, the 1UZ and the 1JZ automatic trans bell housings have the same mounting . . . . .
. . . . they just are not the same DEPTH.
So, what to do. There are two possibilities: one -- (best, but not what I am going to do) is to disassemble my 1JZ built racing trans and install the input shaft (and pump) from a 1UZ of the correct input shaft length (assuming that they fit . . . . and I do not know that they do); or two -- make a spacer ring (with a pilot bushing allowance) between the current flywheel (ring gear) to ANOTHER flywheel which will have the torque converter bolted to it, and bolt it all onto the crankshaft. The length of the "spacer ring" is about 2 inches. It will work, and only adds the weight of the spacer ring and the additional flywheel (it will fit inside the 1UZ bell housing). I will do this at the machine shop using a dummy block for measurement.
What would YOU recommend?
. . . . they just are not the same DEPTH.So, what to do. There are two possibilities: one -- (best, but not what I am going to do) is to disassemble my 1JZ built racing trans and install the input shaft (and pump) from a 1UZ of the correct input shaft length (assuming that they fit . . . . and I do not know that they do); or two -- make a spacer ring (with a pilot bushing allowance) between the current flywheel (ring gear) to ANOTHER flywheel which will have the torque converter bolted to it, and bolt it all onto the crankshaft. The length of the "spacer ring" is about 2 inches. It will work, and only adds the weight of the spacer ring and the additional flywheel (it will fit inside the 1UZ bell housing). I will do this at the machine shop using a dummy block for measurement.
