HarperRacingBangkok
Thanks guys: I will be at my shop today with the tuner/mechanic and the wiring guy . . . and the first thing I will check is the cam timing.
Jeff, if you're running the AEM for the Supra, it's designed for use with variable reluctor (VR) type pickups which are the standard type found on the 2JZ-GTE motor.
Since the 1UZ has 2 cam sensors, and the AEM only needs one to trigger from, you should be able to swap sensors. For my setup, and all the others I've seen using the AEM, we've used the left hand bank cam sensor (cylinders 1/3/5/7) for the AEM.
We should have let us know. David and I are 30 minutes from LA.I am just back from Los Angeles now, but go to Italy in three days . . . . too much travel and not enough racing. I purchased an MSD DIS-4 Plus (CDI) while in The States, so I will have my guys install it while I am gone. In two weeks I will be back at it at the track for test and tune . . . . I hope!
