Doc,
Looking mighty good.
I can already see those front whees lifting in the air.
I see you have a belt tensioner on your supercharger belt but it looks like it is on the tension side of the belt. You may find this causes belt slip, if it does you may need to put it on the bottom side of the belt. As far as bleeding off boost at idle goes I suspect it will be one of those trial and error things until you find the right set up. Start with the lowest spring and go up from there would be my suggestion. With non std cams etc it's hard to know what the idle situation will be like without running it.
