earthman
ENGINE INSTALLATION PROPPER: Cooling Issues
Cooling, or lack there of, has been an issue for many guys doing this conversion due to the smallish engine bay creating restricted airflow. I did a fair bit of reading to see what other guys had done and discussed this at length with the mechanics before I handed the vehicle over for the conversion.
Before I took the vehicle to the mechanics I moved the winch box under the bonnet near the brake master cylinder. This normally sits smack in the middle of the bull bar in front of the radiator and robs it of air. Moving it inside the engine bay gives it a bit of protection as well as creates more airflow through the radiator.
I ordered from Scott at VENOM COBRAS in Qld an alloy radiator for about $700 that fits the 4runner. It is apparently a Nascar quality AFCO Racing radiator. Scott was able to get the exit and entry holes welded on opposite sides as the V6 and V8 have their hoses on opposite sides. This radiator also had the support brackets welded half way along the tank.
The new alloy radiator was recessed forward to create more room for thermo fans between the engine and radiator.
In short, the front radiator panel support was cut and enlarged to recess the radiator forward, taking advantage of the radiator support brackets welded half way along the radiator tanks. This created more precious room between the fan and pullies on the front of the engine – remember we are fighting for mere millimetres here.
