earthman
PRE-CONVERSION WORK ON A341E GEAR BOX
Probably the most complicated part of the swap (complicated for me anyway) has been the adaptation of a transfer case to the 1uzfe auto gear box. This was achieved by getting a Toyota Surf auto box (the kind with the electric engaging manual shifting transfer case) and joining the transfer case to the 1uzfe auto box.
I followed this process from others who have gone before me and posted their (excellent) ideas on the net. I will go through the process that I followed but I would suggest that you look at the following sites as I basically copied what they did and they have much better info and pictures.
Madmont: http://lextreme.com/forums/showthread.php?t=5906&page=2&highlight=output+rotor
Duza: http://www.4wdmonthly.com.au/forum/showthread.php?p=693678&posted=1#post693678
Some good info from Cebby too at: http://www.lextreme.com/forums/showthread.php?p=34828
There were several major steps to this process. These were:
1. Drilling/locating new speed sensor on transfer adapter housing
2. Cutting the output shaft
3. Cutting and fixing the 4 prong speed sensor rotor
4. Assembling the Gearbox/transfer combination.
5. Creating transfer case relay panel – DISCARDED after installation of manual transfer case
6. Creating Relay wiring - DISCARDED after installation of manual transfer case
7. The decision to switch from electric shift transfer case to manual shift.
8. Transfer case compatibility and adaptation from electric shift Tcase to Manual shift Tcase.
9. Adaptation of Tcase Shifter Levers
10. Adaptation of Speed Sensors
11. Adaptation of speed sensor
The diagram below shows what part fits where. This is a modified picture I pinched from a Lextreme forum member and I am sorry but I can’t remember who submitted it. I hope in the name of the advancement of 1uz knowledge that using it was ok, but if it is yours and you don’t want it on here please let me know!
