POST ENGINE INSTALLATION: Transmission
There was a leak from the transmission main seal around about the same time as the alternator issues. It started slipping really bad. When I checked the dipstick it was bone dry. Because of the slipping I anticipated there may have been some damage inside. I spoke to the mechanics and they agreed and that I may need a rebuild or new gearbox. I decided to try to get a new gearbox.
My engine and gearbox were from the 95-97 LS401/Celsior, part number 35000-50082 (UCF20 and UCF21 models I think) and all that were available (from SSS Automotive in Girraween) were gearboxes from the 90-94 LS400/Celsior, part number 35000-50050 (UCF10 and UCF11 models I think) I started doing some reading and asking around to see if they were cross compatible.
The gearbox number I had was 35000-50082, the older ones were 35000-50050. Physically the boxes were very similar except that 50082 had one speed sensor on the tail housing (presumably a combined one for the ECU and dash) and 50050 seemed to have an extra speed sensor (An electronic one for the ECU and a gear driven one for the dash). I spoke with Sideshow and he told me that as long as the main plug (there are 8 pin versions and 6 pin versions, mine was 8 pin) and the position switch plug would fit the harness (there are apparently larger and smaller ones, mine was larger) there should not be any issues. So I took the plunge and got a 35000-50050.
There had to be a couple of mods to get the transfer case to fit: cutting the output shaft and speed sensor rotor etc (this is all covered earlier in the build). And while everything was apart I had the hole at the centre/bottom of the gearbox/transfercase interface drilled and tapped out to 10mm course thread for that bolt I was too lazy to put in last time (see photo).
Once the whole lot was back together, rather than fill it up with generic Dextron IV I went to Toyota, paid the extra money and bought some Toyota Type IV transmission fluid. The transmission was filled up with this. I was using Dextron in it before. I don’t know if the dextron contributed to the transmission issues but from now on Toyota Type IV transmission fluid is all I have used it, as recommended.
The vehicle was tested and worked fine. It has been driving perfectly ever since both on and off road with zero issues.
