Jibby's is definitely a dry system,probably a 5121 or 5122 system from NOS (Nitrous Oxide Systems)
See those two solenoids at the upper lefthand corner,seperated by a T fitting. That's a dead giveaway of NOS' dry systems.
Dry System = Only nitrous is injected through the nozzle. Fueling is through the fuel injectors,either mechanically (increasing fuel pressure) or electronically.
NOS has both. At the tee on Jibby's system,that vacuum hose connects to the fuel pressure regulator's vacuum fitting. Since nitrous comes out at high pressure,this presses down against the regulator's diaphragm which in turn increases fuel pressure.
Their LS1 systems passes nitrous through the MAF,ECU reads a very cold intake air temp (sensor is in the MAF) and increases fuel delivery.
ZEX does it mechanically,has a similar dual solenoid/tee setup inside that purple anodized case.
Venom's dry systems are electronic,you have to tap into the fuel injectors' wiring so the system can change injector pulsewidth.
Wet System = Nitrous and fuel injected together through the nozzle. A single-fogger has a single nozzle before the throttle body (like a dry system),direct-port has individual nozzle(s) for every cylinder,you either drill/tap each intake manifold runner or those new fuel injector spacer/nitrous nozzle things that NOS and Nitrous Express make.
I've installed NOS dry and direct port systems,also have installed a ZEX system or two.
