cebby
A few more pieces of the puzzle:
A340F trans and t-case from a 2000 4Runner V6, 67K miles. After checking out the connectors on the trans, I will likely just use this A340F instead of converting the LS trans to 4WD. There are 3 plugs. Two are identical, one is slightly different, but had I think it had the same number of contacts. I'll just need to get a pigtail for the a340f and splice it into my 1UZ harness.
The LS torque converter fits the input perfectly, but it's clear the VZ bellhousing won't work on the UZ engine. It's too short and the bolt pattern is different.
I was investigating the various dual case adapters (MC07, MC08, and MC08-R10) and it was recommended that the MC07 is perfectly fine to use and that there is no significant advantage of using the MC08. See this thread: http://www.pirate4x4.com/forum/showthread.php?t=366164
OK, who needs a transfer case? And what is all that "stuff" hanging off of the tcase in the last pic.
