hungryforinfo
How did you get your motor so damn clean, you could eat off that!
Looking good John, I was just in Houston, I should have tried to set somthing up to come see this thing. Just remember when its dyno time, I may need to make a road trip.
What stops the supercharger pulley spinning on the front of the supercharger? Just the tension on the M10 bolt or is the adapter a press fit on the shaft as well?
John,
Are you planning on an idler below the supercharger?
Doesn't seem a lot of wrap even for a cogged belt.
You're mighty talented at swapping from Imperial to Metric dimensions and back.
That's looking very serious John
I think the PS pump will be fine just on recirc...it's not doing any 'work' so won't get very hot.
Just on the belt path. Run the standard idler puller just below the SC (see my pics). I modded mine so it would pivot and i could use it to help set a higher 'base' tension on the beelt as well. If you could fabricate anothjer smaller idler pully to replace the fan pulley it would help as well i think as the belt path would be nicer? You be running thermos anyway so no need for the fan?
Justen do you have a link to your pics? I'm feeling lazy and not wanting to troll through your 30 page thread![]()
