krayn said:My very limited understanding of turbos has me thinking that a turbo will only produce boost in psi or whatever in the inlet manifold when the volume, or pounds per min, output of the turbo exceeds the ammount of air the engine is consuming. So I thought that boost in psi goes hand in hand with turbo flow and the air volume the engine is consuming. Is my line of thinking wrong? Kris
Exactly my point. A 1UZ with stock heads isn't going to flow ****, and thus no matter what turbo you stick on it, you're still not flowing **** at 5 psi. Boost is a measure of flow which is NOT entering the engine, so they ARE related. You can't just base everything off the turbo's mass flow because the engine has to be able to breathe just as well in order to use it. There are two axis on a compressor map, boost and mass flow rate. The mass flow rate axis is not for the turbo. The island is for the turbo. The mass flow rate would be the indication of how much air the ENGINE is breathing.
Toysrme said:rarson two things.
1) learn what you're talking about.
I'll reiderate... psi has nothing to do with anything. The mass of airflow the compressor moves is the only relative bit of information that is useful.
If you took a bobcat turbo and ran it at 20psi, you would have a 100-120bhp 1uz-fe. It's 22psi comming out of the compressor, but guess what... It doesn't move much mass.
You don't get it, do you? If the turbo is undersized, you'll never get to 22 psi! How do I know this? Take a stock T25 on a 4g63, and disconnect the wastegate. The turbo can't hold 15 psi past 5500. Why? Because the engine is breathing more air than the turbo can push! It's called proper turbocharger selection, and it involves all aspects of the turbo, not just the compressor, but the turbine wheel and housing as well.
Toysrme said:Likewise, there is no limit to how high-flow of a unit you can buy.
There are pleanty of industrial turbo's that would split any gasoline car engine in half at 5psi, I'm sure if you hooked a marine turbo up from a huge diesel ship, you could split one at 1psi...
Again, you don't get it. Maybe you should learn what you're talking about. If I take that same 4g63 engine and put a huge turbo on it, I'd probably never even get to 5 psi because the turbo would always be flowing more air than the engine. You can't split the block at 5 psi because you can't get to 5 psi!
Toysrme said:Again... PSI doesn't mean crap. The MASS of flow means everything.
2) Learn to read something in context.
I will agree that boost is a generic term, because many variables affect it. Just because someone says "I'm running 20 psi" doesn't mean they are making x horsepower. I will agree that mass flow rate of air is a much better determination of power production. However, in proper turbocharger selection, boost DOES matter and that is why there is a pressure ratio axis on a compressor map. Just because you don't think psi means crap doesn't mean that someone shouldn't size their turbo appropriately for the amount of boost they want to run.
Oh, and it does mean crap, because altering the boost level affects other things like fuel delivery and cylinder pressure. So at 11 psi, no matter WHAT turbo it is (as long as you can actually make 11 psi), you're putting less peak cylinder pressure onto the engine than at 15 psi.
