turbo question
vvega
when would you think a t70 with a .86 hot side would spool on a 1uz ??
basically what rpm
thanks for your time
v
I have one of these turbos to go on to the 1uz. Hope its at 10 psi by 3500, and starting to boost at 2500???? Will know in about 6 months time.
You wont have any problems with 4 liters of displacement. If you run a slushbox be sure to get a higher stall converter.
i was looking for experance with people that have used the combo thats all
calculations and predictions dont really hold a light to real world facts :D
not tring to be offensive at all sorry if i come across that way :D
cheers for your time
v
You're right, turbine sizing is not the exact science that compressor sizing is.
Saw your project on mr2oc, nutty as it gets, love it! looking forward to updates :)
cheers murphy the support has been increadible
the 3s bell is certanly tring its hardest to be difficult but i am quite determend to get it perfect
they have absolutely no holes running on the same raduis from the centre and there is no pattern to there placement
ive had to resorth to useing our scanner to get the pattern correct,still have to correct the alingment to:S
v
