Project Thread afm turbo question???
Are you refering to blow through as against draw through MAF ?? Alot depends on how the MAF is calibrated... Blow through measures the real density etc and calibration of MAF isn't pegged "as easy" due to denser air...
Draw through can be just as good also.. Pita with twins...Also doesn't measure any variation in heated inlet air... Yes the inlet air temp is there ...Density changes with heat...
Most the Mustang guys prefere blow through...
