Cheers Cobolt, some good thoughts there. I'm beginning to appreciate why Zuffen is planning to use the underside of his manifold for some of these.
Now the latest problem/issue - I have all these nice Supra COP's, and the AEM to trigger them, but I need some ignitors, since the Supra COP's are dumb coils.
The OEM Supra ignitor isn't a good choice since it doesn't like to be run in waste spark mode and needs an amplifier like the HKS DLI to work successfully.
I'm tempted to try some generic Bosch ignitors such as the 4 coil 0 227 100 211 model. Anyone know if these are the dumb type or do they do dwell control? I wonder how fussy different ignitor and coil combo's are? Do Bosch ignitors speak Japanese? Or can the Supra's Denso coils sprecken zie Deutsche? Burning questions.....
I must admit I'm also tempted to homebrew some VB921's, make my own ignitors, and save $200. And with my luck, this homebrew rig will probably last just long enough to get me into a cellphone dead zone....
30 December Edit:
Just to update this post, I ordered up some of the Bosch ignitors (which
are the dumb variety I learned, so the dwell has to be controlled by the ECU), and I also ordered some Fairchild IGBT's to build my own ignitors if I get around to it. Apparently the VB921 IGBT's are giving problems in high dwell situations with the Megasquirt crowd, and they tend to let their smoke out occasionally.  And as we all know, once you let the magic smoke out of an electronic device, that's it.
Also, just to be on the safe side, I'm going to get in a set of (8) Tundra coils with integral ignitors.
So I should have the following ignition combo's to test and fool around with:
1. Supra coils with Bosch ignitors
2. Supra coils with Cribbj built ignitors (not likely to be the final result)
3. Tundra coils with integral ignitors
4. Nissan VQ coils (350Z, etc.) with integral ignitors (the AEM wizard I'm working with is very high on these coils, but we're anticipating some fitment problems.)
I purchased the Bosch pieces from 9Motorsport:
http://stores.ebay.com/9Motorsport-...QsspagenameZADMEQ3aBQ3aEOIBSAQ3aUSQ3a60QQtZkm
And the Fairchild IGBT's from RS-Autosport:
http://www.rs-autosport.net/catalog/product_info.php?products_id=253
Very good service from both the above. Here's some pics:
This is the low power side of the Bosch that the ECU talks to:
And the high power side which is connected to the coils:
Here's a great connection diagram for the Bosch, courtesy of those nice people at MoTeC, who put lots of useful info like this in the public domain:
The Fairchild IGBT; it's not current limited like the VB921's, so if we run too much dwell, the coils will fry. (I can't believe this little puppy is rated to pass 10 amps, but it requires a honker of a heat sink too....):
That's an inch ruler by the way, so the actual chip is only around 3/8" square!
