Gang, it has been several weeks since I updated you on the mechanical aspects of my project…So here's an update of my progress… I have resolved the fuel pump wiring. Instead of running two separate fuel pump outputs and leads from the SM4, I decided that I would only use the main default output to run both pumps simultaneously. The default fuel pump output on the SM4 is now connected to both pumps and I split the trigger wire to both relays (one to each pump), and it is working perfectly. Both pumps stay off until I turn on the key, then the ECU primes both pumps and shuts them off until I start the motor. I think the secondary output that was reprogrammed lost its programming, perhaps after the ECU was re-flashed. Anyway, I will always run both pumps instead off staging them. Probably safer anyway. Now I have only to complete the installation of the water/meth injection, and connect the boost gauge. Btw, the base map is running well, and should be good for non-boosted driving. It is still a bit rich, but I will lean it out am little this weekend. I adjusted the idle set screw because the idle was very low (450 rpm), once I did that, it stopped idle hunting. I'm planning to drive the car this weekend. Final tune should be within a few more weeks. If the drive goes well this weekend, I will drive it over to Tampa for the final wet sand, buff, and repaint of the front fender.
Ryan
Ryan, be careful running both those simultaneously, all the time at 12v. You're going to be bypassing an incredible amount of fuel at idle & cruise. Be sure your return line is up to it, and your tank venting is too. You're going to have "a lot" of vaporisation.
If your return system isn't man enough to handle all that fuel, it'll cause a restriction, which will cause your FPR to go nuts, and you'll be running rich at idle and cruise. If you lean it out to compensate, then you'll be too lean under heavy boost = very dangerous.
You know that I'm a Kenne Bell BAP fan, and for me, that's the best solution, however failing that, if you've run out of outputs on the Autronic, you could always trigger the 2nd pump with a simple Hobbs switch set to 5-10 psi.
