Jeep Cherokee Lexus V8
OPERATION - 5 VOLT SUPPLIES
Primary 5–volt supply:
² supplies the required 5 volt power source to the Crankshaft Position (CKP) sensor.
² supplies the required 5 volt power source to the Camshaft Position (CMP) sensor.
² supplies a reference voltage for the Manifold Absolute Pressure (MAP) sensor.
² supplies a reference voltage for the Throttle Position Sensor (TPS) sensor. Secondary 5–volt supply:
² supplies the required 5 volt power source to the oil pressure sensor.
² supplies the required 5 volt power source for the Vehicle Speed Sensor (VSS) (if equipped).
² supplies the 5 volt power source to the transmission pressure sensor (certain automatic transmissions).
This is what I could find in the FSM regarding the Crankshaft & Camshaft Sensor. So far
