The 1uz VVti is DBW but the APS is located on the TB and operated by a Cable to the TB. Most of the time I find the Calibration Of each manufactures APS units needs to be exact so interchanging between manufactures is not practical with factory ECU. Im just doing a 3uz in a 08 hilux and using the factory APS but using a link xtreme to take care of management. Tested it all with a scope and it looks ok but time will tell when its all connected and tested. This model only runs CAN if auto and this one is manaul. The dash is normal except for the water temp gauge which runs off a PWM from the ECU(the link will control this).
I would be checking all the Communication links between all the processer units on the Jeep. CAN cannels can cause issues and often the late vehicles ECUs are also daisychained together. I did a isuzu V-cross and the ABS , airbag and engine ECU shared Seriel links but the info flow was from the Airbag and ABS to the ECU with no reverse feedbacks. I check as much of this stuff before starting the jobs where I can. Even simply stuff Like alternators are often ECU controled now.
It is often neccessary to wire a Vehicle system , a Toyota Engine system and them a intergration system between the two and modify signals to suit. Clever aftermarket systems with configurable signal outputs often make life easier.
