Hi Guys
So I finally got the Jeep started this weekend, and let me tell you there is no better sound in the world, it was like christmas for me when she fired up.
Anyway, before I got to starting it, I battled a bit with getting the gearbox back on to the engine, with the engine installed. So finally I had to take the engine out, and install the gearbox on the floor. After all the work of unplugging all the wires and pipes and taking the engine out, it took a very little nudge to get the gearbox on. So after that was done I decided to extend the exhaust manifold while the engine was out, so once finished with welding on the extra pipe, I reinstalled the engine. And like the jeep has been through this entire project, I had to change the engine mounting brackets, as the engine would not fit again. So I had to lift the engine and move it forward a bit. So I finally finished that up, and reinstalled them, got all the wiring plugged in, and started to try and get the jeep started up.
It didn't want to fire, so I thought I would have to go and open up all the wiring again, to do some fault finding, but luckily I figured out that I had connected the 12V feed wires running to the relays, to the diesel's glow plug heater relay. So I quickly cut them and connected them directly to the battery, and about three or four turns and she fired up.
At that very moment I am sure I was the happiest man alive, it felt like winning the lottery.
Hey wynanddb
Yes the wiring was quite a struggle, but luckily I downloaded the wiring diagrams for the jeep from the internet, and alot of help with the forum members, it made life a little easier for me.
But yes I must say I have lost all faith in the Jeep Diesel Engine, I have heard about so many people that lost their engines a few times, it seems that they only know how to make a petrol engine. Anyway you can fire away with the questions, I am sure I will be able to help with them in some way.
And as for the gearbox and transfer case, I decided to make ('n boer maak n plan) adapter for it. As I took the end piece of the jeep shaft, and got the engineering shop to precisely line up the shaft with the shaft of the lexus gearbox. The guy then shrunk the piece over the shaft of the lexus, and welded it for extra strength and durability, he guaranteed me that I would rather break a drave shaft than, the shaft that he shrunk and welded. Then he made an adapter plate out of angle iron, and closed it with plate. Now on the original jeep the shaft running into the transfer case used to run in oil. But it will now run dry, so that is the only major change I have done to that part.
And as far as costs goes, I have spend about R 19 200-00 so far, with the breakdown as follows:
Engine and gearbox: R 5000
Spitronics management: R 6200
Engineering: R 4500
Tools & Equipment: R 4000
Then I still have to sort out the cooling system, which I will try and get done this week. Then I have to go back to the engineering shop to get spacers made up for between the shocks and the body, as I need to lift the jeep about 70 mm, because the space between the arms on top of the front diff and the engine mounts are too close for comfort, so the first time I get to a croos axle situation I am going to loose an engine mount.
Then once the height is correct I have to measure the spize of the drive shafts and get them done.
Then it is only small things like aircon left to do.
But I will post some pics again this week.
Cheers for now
