The 1uz and 3uz heads should not be interchanged.
The piston shape on a 3uz uses an angled quench surface and the diameter is larger. You want to use 3uz heads on a 3uz.
Both engines are 10.5 compression but 1uz heads on a 3uz will at the very least raise compression and may have piston to head and possibly piston to valve interference.
