Progress has been slow, I hope to get some work done between now and the end of the year. I have some time off and when X-mas gets done I am in the shop.
For now I have been buying more stuff to complete the build. I am really focusing on the interior, It will be different and out of the box.
I got a second wide band to monitor my left bank of cylinders.
I also bought a Stillway shifter. I am not sure if I will use it or not. It actually turns into a inline shifter with a pull. Then it can go right back to normal operation. The thing that bums me is I dont think it will allow me to use the Momo shift knob I bought.
Here is what the say about it.
"This Japanese Stillway sequential shifter adaptor kit is for your factory Getrag 6 speed transmission. This modification to the factory shifter allows you to lock out the traditional shifting scheme and go sequential. Intended mainly for drag racers you can then do the 1-2, 2-3, 3-4 shifts by simply pulling up or down on the shifter!!! This means NO more missed shifts, ever!!! Shifting is available only in upshift mode, but with a simple flick of the switch you can return to the factory shifting pattern. This part does NOT require the transmission to be dropped and is installed very similar to a short-shifter. The kit contains a special shifter, shifter slider/ring assembly and hardware to attach and utilizes the existing factory main shifter."
Otherwise, I have got bought all the factory TT boots new, 3 lower boots total.
I am getting ready to gut my interior to prepare for new parts plus tunnel modification.
