Hello Gloverman,
Thanks for the information, really appreciated. Can get a bit mind boggling on your own.
On the earthing issue, I did add another earth lead to the engine, one from the cylinder head, and it now has two from the block to the chassis. At one point the engine wouldn't even turn over when one of the the earths had been disconnected from the block. Hopefully this is not an issue any more, maybe need to add another ?
I've seen a few scan tools on ebay, however they all seem to be for OBD2, I really need to wire in a oval plug to the loom first. Do you have any for purchase ?
I'm going to test the AFM wiring again, it's been a while and can't remember the exact results from last time. I almost considering just running a new AFM loom back to the ecu with five wires new wires. Is that sound thinking ?
Further to this get in on the dyno, compare the two ecus I have.
MiNes ecu
MiNes ecu without afm
Stock ecu
Stock ecu without afm
Look at power, torque curve, AFR's
After that if it can't be sorted, not sure ??
