extractors
Hello fellow Lexthusiast's,
I will cut great to the chase, I have a 1UZFE in a 76 s class mercedes.
The donor car was a 1994 Celsior/ls400. Its running std ecu, and 4 spd trans.
Now when I disconnect the AFM, it runs great, heaps more power through out the rev range, heaps more torque and punch down low. Only problem is it runs well rich, and has a 5,500 rpm rev limit.
Now with AFM connected, it turns into "dog mode", absolute slug, at anything under 3-4k, you really have to work it to do anything. Once you get it on the highway, it does seem ok, not great just ok.
Now for time being Ive rigged up a switch, so I can switch between AFM, and no AFM. When the switch is flicked, there is an instant urgency with the car, when its set to AFM again, "dog mode returns"
Now, Ive got two ecus, and neither are throwing fault codes. Once ECU is a MiNeS ecu, I even went to the trouble of sending it to Japan, to have the once over. They said it checked out fine.
I have tried 3 different AFM'S, I have a V8 soarer aswell, so can easily swap parts around. The V8 soarer, goes very well for a stock v8, and I know the afm on that is working a ok, and pulls nicely on the dyno.
The car in question has the following.
New timing belt, idlers, pulleys, bearings, seals, water pump etc
New rotor buttons, dizy caps, leads, platinum ngk plugs
New (aftermarket coils)
Original igniters.
New 4 wire O2 senors ( have checked voltage output, including heater wires, and all checked out ok)
Custom headers, twin 2 inch into single 2.5 inch exhaust, no cats.
Ive set up TPS to factory specs,
set idle, cleaned IACV, checked for vacumm leaks, replaced all vac lines.
New water temp sender
Ive checked compression, 180-182 psi on all cylinders
Done several upper engine cleans, injector cleans etc.
Car is running a factory mercedes, 094 Bosch external pump.
I'm really out of ideas now ??
Is there anything I'm missing here ?
Brett
Original igniters.
Brett
