if your using megasquirt v3 you dont need to use the edis setup as it has the ability to run coilpacks. so if you just get two ford mondao coilpacks the v3 megasquirt will run them
I am glad you ask that question. The stock wheel is .070" but its stamped and the thickness change from .070 to .25" from the base to the wheel. That is why we use two plates to make up the difference. I am not sure if you can view this picture or not but here it is.
The smaller wheel acts as a spacer. Right now I have no use for it. If you guys need different number of teeth please let me now. My guy have the basic drawing already and it can easily change to whatever teeth you want except those for high number of teeth. However, he prefer an order of 5 is possible. Since he is nice enough not to charge me drawing fee.
Actually, my machinist made a mistake. The larger wheel should have bigger hold to clean the crank pulley insert. I will make those changes. 4 flat head allen bolts will work. I will post some new pictures when available.
Nice work bro... can you cnc them into 60 teeth? I think John was asking me that.
CJ,
I talked to my guy with a laser cutter and he stated it can not be done. What type of machine will you be using to accomplish the 60 teeth wheel?
