The answer will be NO.jgscott said:As I asked of my second question about the stage 1 porting, I was asking what possible HP could be acheived ? And if anyone has actually done this and what was the result. I kinda of have a issue with this, as I know that a correctly ported head and valve work can improve the HP of a stock engine.
Just for refference I talked with Chris of AARP http://www.anderson-audio.com/projects.html. He owns many track records for Supra's and builds many 1000 + HP Toyotas. He thought that saying your could not acheive HP with porting and bowl work on the Non VVTI 1UZFEwas totally incorrect. He also mention that the NON VVTI V8 , N/A motors responded even better to porting and bowl work than others and would produce a true HP gain if done the right way.
My post was an inquire of anyone who has actually done this type of head work or know of, on the 1U- Non VVTI and there comments and actual results. I respect anyone's guess, but was seeking someone who may have actually done this on their car. Not someone who had a inexperienced opinion, and untested feedback. If edma65 has actually flow bench ported and worked the heads, and experienced results that dynoed 0 gain, then I guess I misunderstood or the heads were done incorrectly.
Sorry sincerely did not mean to confuse or flame.
BTW I have a 97 SC400 w/ BFI, X Dual, Unichip, 125 Shot Zex, and a few other Mods.
* Different piston configuration
* Different head angle
However, if you can get a complete VVTi upper (heads and up) then it would work, but again you would have piston issue. To concluse your question, its not worth the money and time. If your desire is to have the 3uzfe, then you can do this:
1. complete heads and uppers (intakes and others)
2. Custom pistons to suite the 3uzfe heads
3. Other issues (VVti, fuel and ECU)
The cost might run up to 5k or so.....
