Guys,
the 1UZ LS400 with T88 is finally running!
Since we progress on the rwhp stage by stage we kept the stock ecu to begin with.
The T88 is currently only making 3-4 psi on "full" boost with AFR 10-10.5 so enough room to increase boost. We also use a Virtual exhaust system and external wastegate.
We now how the following "problem": when cruising (no boost) and SLOWLY braking the car nicely brings the rev down to idle position. But when driving (let say 30 mph,no boost) with ABRUPT braking the car can't keep the idle position and dies.
We already closed the wastegate and lenghtened the air intake (maf to close to turbo) because we thought of "compressor surge", this seems to help a little but still not solves the car dieing under hard braking.
This problem is even worse when coming from 6000 rpm and braking "hard"..
Any suggestions what to try ?...we do want to keep the stock ecu for now...
ps.what psi the stock ecu can handle (i read 7psi, but didn't find an explanation)..will the AFR go > 11.5 when boosting more then 7psi ???
THX !
:biggthumpup:
THX !
:biggthumpup:
