Parts 1uz turbo project part out
Supra967
UZA70 turbo project part out. No time to finish this with pregnant wife and half finished renos, so i’ve bought another car and need to sell off this gear.
Radiator - $500.
Mounts in place of the factory ac condenser on an A70 supra. Custom made brass/copper, 3 row core 56mm thick. Would need inline filler somewhere, i was going to weld the rear water neck and fill from the back. Comes with 967 amateur welded top rad hose to fit 1uz
http://www.supraforums.com.au/forum/members/supra967-albums-my-70-2-picture43324-rad-2.jpg
http://www.supraforums.com.au/forum/members/supra967-albums-my-70-2-picture43325-rad-1.jpg
Motor –
sold
Engine mounts –$100
these will put a 1UZ on the standard 7M isolator for a pre 89 supra cross member. Made from 10mm plate, with the UZ bell housing bolted to the 7M gearbox using standard 7M gearbox cross member and tail shaft etc. I believe a crown uz auto will bolt straight up (never checked!) or go for a hybrid auto box as I was going to do.
http://www.supraforums.com.au/forum/members/supra967-albums-my-70-2-picture52343-100-5352a.jpg
http://www.supraforums.com.au/forum/members/supra967-albums-my-70-2-picture52344-100-5353a.jpg
Adaptronic E420c ECU with 3bar map sensor and 2m loom. Brand new unused - sold
Injectors – 12x 7M black 440’s. All second hand from working cars - sold
Coils – 8xlandcruiser, second hand from Japan p/n 90919-02231 - sold
1UZ machined oil filter adapter, brand new never used - $150 (fittings not included)
http://www.supraforums.com.au/forum/members/supra967-albums-my-70-2-picture52342-100-5351a.jpg
Exhaust manifolds - $400
Cost me more in parts alone. Computer designed, amateur welded, extremely tight 4 runner manifolds for front mounted turbos, flanged to suit GT25. 1.5in stepped down to 1.25. Needs relocated PS and AC, and custom studs in some parts. Needs die grinding at the engine side to finish off. Should be good for spool up, but maybe not so much weld durability. Can be supplied with the jig.
http://www.supraforums.com.au/forum/members/supra967-albums-my-70-2-picture52339-100-5346a.jpg
http://www.supraforums.com.au/forum/members/supra967-albums-my-70-2-picture52340-100-5347a.jpg
http://www.supraforums.com.au/forum/members/supra967-albums-my-70-2-picture52341-100-5349a.jpg
Frozen boost china spec water to air intercoolers. Brand new unused. Two 4x8in barrels and 1 24x12x1 heat exchanger. Look pretty good for the price
Barrels - $160 each
Exchanger - $110
http://www.supraforums.com.au/forum/members/supra967-albums-my-70-2-picture45337-wta3.jpg
PM any questions
All items in Wollongong, NSW. Postage would be uncool but inevitable.
Matt
