STORMINORMAN
- Messages
- 4
- Location
- PacNW
1993 SC400, 95K miles, starts, idles, shifts & drives great (IMHO). Standard sized 225/55-16 tires, no CEL's (but the check engine light does come on and then turns off at start, as it is supposed to)...
Speedo consistantly 10-15 mph lower than actual speed! Dash is bright, needles all move smoothly, no indication of any display problem.
I've been advised that the OBD I system should not have any "stored codes" if there is no CEL, so the dealership's $ugge$tion that I "bring it in for a diagnostic (at $120!)" doesn't make much sense to me: I can buy an OBD 2/OBD I scanner with accessory cables for Toyota/Lexus, Ford, GM, etc. for $199, but what good is that going to do if there are no "stored codes" to begin with?
I'm advised that the VSS1 & VSS2 codes are 42 & 61 respectively...
1st posting, I'm a Newby, 1st Lexus V8 as well. Possibly my only vehicle with OBD I as well, I know for sure none of my other cars/truck are OBD 2.
Just trying to avoid a repeat of the conversation I had Friday which began with "Sir, my radar had you going 71 mph in a 55 zone..." and my speedo was reading between 55 and 60!
Thanks in advance for your kind consideration and any ideas, other than the suggestion I just buy a GPS and use it, most likely more accurate as well?
