Red Supra
I'm back with pictures and a short movie.
Lets rewind first.. back to fall 2009. First motor became a casualty of 25psi and 20 degrees of timing on 93 octane.(my own fault) That fun excersize resulted in a cracked piston skirt. But for the split second it made about 380rwhp. Picked up a junkyard motor for 400 dollars, 24 hours later I was back in business. Drove the car for about a month and during one of the last nice falls days the driveshaft broke. Poor welding, no penetration. Now about a month ago i got a replacement driveshaft for the car and started driving it everyday. Running 9psi currently on 67mm turbo.
http://www.youtube.com/watch?v=KJp_8wssHho
broken driveshaft:
http://maxveprinsky.com/upload/supra/broken_driveshaft.JPG
can u spot which cylinder had the cracked piston?
http://maxveprinsky.com/upload/supra/DSC02587.JPG
lots of little things to finish
http://maxveprinsky.com/upload/supra/DSC02588.JPG
looking straight down
http://maxveprinsky.com/upload/supra/DSC02589.JPG
upskirt 1
http://maxveprinsky.com/upload/supra/DSC02590.JPG
upskirt 2
http://maxveprinsky.com/upload/supra/DSC02591.JPG
trans and ps coolers
http://maxveprinsky.com/upload/supra/DSC02592.JPG
TH400 w/transbrake
http://maxveprinsky.com/upload/supra/DSC02594.JPG
turbo mounted low
http://maxveprinsky.com/upload/supra/DSC02595.JPG
how many turbo cars can you spot?
http://maxveprinsky.com/upload/supra/DSC02596.JPG
Today I changed all fluids in the car and started using Valvoline VR1 20w50, it is actually to thick for standard bearing clearances, oil pressure hits 100+psi over 4000 rpm, need to go back to 10w30 and add oil cooler. With 10w30 I had ~70psi at 6500 rpm but it gets super thin when cruising at 4000 rpm for 20 minutes on highway as things get pretty hot.
I'm going to put a GM flex fuel sensor on the car and let the ProEFI control boost and timing when it senses ethanol or E85. I don't think I can turn the boost past 11-12 on pump gas on this stock compression motor with weak pistons.
broken driveshaft:
upskirt 1
upskirt 2
TH400 w/transbrake
turbo mounted low
