Paul,
Any dyno or ET numbers?
Taken from Aero's site (I hope you guys don't mind?):
Chassis: Series I Mazda RX-7. AERO full tubular chassis, with 38 x 17 tubs. Two Top Doorslammer type 36" 4130 swing-arms
Rear Wing: AERO 2024T3 Aluminium lightweight aerospace.
Weight: 2300lb
Wheelbase: 97 inches
Engine: Toyota Quad Cam V8. 282 cubes.
Horsepower: 1200hp +
Maximum RPM: 10,000.
Fuel: Methanol.
Injection: Enderle mechanical injection. 110 Pump, Hat, Dribbler and Port Nozzles.
Compression: 9.5
Supercharger: "B" Series PSI Screw Blower
Block: Toyota 2UZFE steel block, fully grouted, O-ringed, Lextreme designed 4-bolt main conversion by AERO.
Crank: Lexus 1UZFE, polished, offset ground.
Pistons CP Custom blown alcohol
Bearings: Toyota mains, Clevite SBC rod.
Rods: GRP SBC 5.7" small journal ally
Heads: 1UZFE Lexus, O-ringed, 100lb Crow springs, AERO under-bucket shim conversion, standard valves.
Head Gaskets: Ridgecrest solid copper
Cams; 4 Crow blown alcohol special grind
Manifold Cast bottom, billet spacer and top plate by AERO
Ignition: Mallory Supermag IV
Spark Plug Leads: 11mm solid core
Spark Plugs: NGK
Exhaust Headers: AERO zoomies
Hoses & Fittings: Aeroquip.
Component Coatings: TBA.
Oil Pan: Bravo Resources 6100 ally, AERO modifications and fittings. Nappy.
Oil Pump
![Stick Out Tongue :P :P](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f61b.png)
eterson external pump. RDC pump drive.
Lubricants: Penrite
Oil Filter: System 1 remote filter.
Bell Housing: Lexus
Gearbox: WAR Race Powerglide Auto
Clutch: FTC High Stall auto - 5,500 rpm
Differential: 9" HD braced housing, 35 spline Moser axles, Mark Williams billet yokes, Romec 4130 full spool, Strange noddy case 3.50" bearings, Spicer solid uni joints.
Wheels: Front: 3.5 x 15 Cragar; Rear 15 x 15 Cragar.
Tyres: Mickey Thompson - Front: 24.5 x 4.5 x 15; Goodyear Rear: 33.5 x 15 x 15.
Safety Equipment: Stroud 5 Point Racing Harness, Stroud SFI-20 Suit.
Special thanks to:
The CREW - tireless volunterr efforts.
Dave from Lextreme - great information and parts supply.
John from Otter Engines - precision engine building.
John Zappia from Zappia Racing - bloody legend.
Vic Donnas from Street Scene - following in his footsteps.
Peter Periano from Pirannah Racing - wild men from Rockhampton.
Danny from Performance Mods - prompt, acurate machine work.
Niel from Sweeting and Denny - prompt, acurate machine work.
Graham and the boys at Southside Engine Center for great machine and head work
Dean from Fremantle Torque Converters for a trick converter
Ben Russell for helping with paint and composite work.
Holy crap! Check out those stats! And Lex, you are famous!
![Big Grin :D :D](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png)
