xtremejags
the 1uz is the perrrfect cat conversion even jaguar put 4.0ltr v8s in the latest jags.1st i got rid of the boat ankor that was in the engine bay set a1uz as far back as was legal ran the headders up and forward cut the steel sump (this was a mid mount sump ) now a rear 1
standard gearbox was used with a3200 stall converter 2 To3/4 turbos custom plannum and 2 throttle bodies + a front mount intercooler microtec ecu remote oil air seperater and remote oil filter sit where the battery use to be battery was moved 2 the boot ross forged pistons were used 2 lower compression i have made mutiple sets of everything including bodykits i drive a standard 1uz in as3 jag as a daily driver but big hp from the s1 is what will keep the adrenaline pumping 1000hp + should keep me happy yeee-haaaa
