I just read this whole thng. and I got to say man I think you have done well and I think that your post and initial write up is very good, everyone appreciates the effort in posting up your findings .
and the effort you have gone to in your build is great.
BUT in regards to the head gasket issues
if the sealing surfaces between the gaskets have been contaminated then it needs to be striped cleaned so it can be resealed when the new gasket is installed. you don't put new gaskets on a surface full of oil and coolant ,you clean everything of it so its beautiful , some even spray copper adhesive to the surfaces before fitting new gasket . I think to all the head gaskets I've ever done and how much scraping you have to do to remove them etc etc . . . they bond and once that bond has been broken well that is it really
and most importantly whilst the heads are off get them and the block decked and hardness tested they could be soft and that could be the reason that thay aren't holding pressure . the hardness test is not evasive nor damaging and is easy to do, and should be done an any aluminum heads and blocks.
with regards to the aftermarket ecus , allot of it is in the hands of the tuner, but it doesn't have to be, you can buy a wide band sensor and go road tuning to get general drivability , idling , cold start tuned by yourself. with the technology these days and the best invention "wideband" there is no reason that a aftermarket ecu should perform inferior in any way . they can even run in closed loop so there is no reason you should fail your emissions tests either.
my 2 cents , long time reader , I don't post much but this got my attention. sometimes its the simple tings that get over looked.
