jibby
What is so dangerous about the brakes and rotor? David you are conviced these rotors should go, I tell you it will work and I just need longer studs, that is it. I think this brake setup will be safer then stock with the new longer studs. The braking is great the ride is smoothe and tight.. I hate spacers but these are amazing....
I had a rear wheel fly off, lugs and studs broke with 3 full turns on the threads. That rear spacer I was using at the time did not have the hub fitment. I also had 500lbs sand bags in the trunk and was riding nos when that snapped and sent my rear wheel flying, and then I road on the rotor to a stop, crazy and stupid. This situation now is a better grab then those that snapped and spacer is 200% better. However, I will still get the longer studs asap,..I am sticking with these rotors as I really see and feel no problems...
