cjsupra90
The center hole is an issue, but not one that will cause a vibration. the hole being to large alows the rotor to to possibly be out of center in a radial direction by 1mm in either direction. this should not cause any vibrations. Some will argue that the rotor being offcenter at all will cause an balance issue, but this is not the case cause most rotors are not very well balanced to begin with from the factory.
Are the the vibrations accuring during braking at high speeds or while driving?
