SuperRunner
So my original project was an intercooled M90. I made a custom intake with custom runners and a top outlet M90 out of an intercooled ford thunderbird. I made a custom water/air box which mounted to the top of the intercooler, then down into the intake manifold.
Lets just say I was very disappointed in the amount of boost I got from the M90, even with the smallest pulley possible. In fact, the car ran hardly any different with the water pump for the IC turned off. Only made a very small difference on super hot days. I did however get a chance to get it dyno'ed. With a 50shot of nitrous I made around 300rwhp with 350ft/lbs of torque. Not impressive at all.
Late last summer I hooked up my AEM from my supra, dropped in some 440cc injectors and ran E85. With this I added as much timing as I could get and still make power using my butt dyno. With my 6-7psi on the charger(non-intercooled at this point due to pump failure) I still got 35 degrees of timing. I also bumped the rev limiter up to 8,000RPM and it loved it.
There were two drawbacks at running the motor that high. The first was the fact that the M90 loses effeciency after about 12,000RPM. I have about a 2:1 pulley on the charger and I run the motor to 8,000RPM the charger was seeing 16,000RPM. Much too high for the poor little guy. The second drawback was that the transmission didn't like it either, and failed on my within 2 weeks.
So now to remedy these two problems. For the supercharger I decided to use the M112 off a Ford Lightning. This will allow me to run the charger at a lower RPM and still gain more airflow. Since the M112 is a bottom outlet I also had to completely re-design my intake setup, so starting from scratch now. For the transmission I will be installing an R154 with my own custom bellhousing and a custom flywheel used from a slightly machined 3.0V6 truck/4runner I however would love to get an aluminum flywheel later on.
This image will continually change to show my updated final status
![sc400_sc.jpg sc400_sc.jpg](https://www.lextreme.com/forums/data/attachments/17/17848-e01452f63423da43bc7b8d5721440b55.jpg?hash=4BRS9jQj2k)
