Sorry for the Basic newbie question but in pulling from a donor SC400 what all should I get??
EklekticMotors
I'll be going the manual trans swap route and I'm aware I will need the ECU and harness, but when stuff goes under the dash etc etc what all should be gotten. I do want to run the stock ECU in this swap. The guy I am buying it from is asking specifics as far as what all i'm wanting. Surely don't want him cutting anything. I've dug around a good bit online and haven't found an exhaustive list of whats needed from a donor car. Any and all help much appreciated!
William
Depends what the donor car is.
You need the ECU and body plug that fits into it.
If the car runs a fuel computer, get it and the loom that runs between the ECU and Fuel unit.
Get the factory diagnostic plug from under the dash and the loom for it.
You need the igniters for the ignition.
If a Soarer/SC400 the cooling computer and loom plus all the plumbing that goes with it.
If late model with security you need all of that and if Drive by Wire throttle that and the loom.
No doubt I've forgotten stuff you need as I haven't swapped a 1UZ for 15 years.
