OK,
After searching, it seems 17 deg at idle is normal, so maybe 20deg is ok? Especially when it's not running on all cylinders?
I jumpered TE1 and E1 and timing dropped down to 10deg. It sounded a lot better, but still not perfect. Even up in the rev range you can still faintly hear that it's not firing on all cylinders.
The only things I can think of now are coils or a blown head gasket (or similar)
Is there no way my Bosch 044 is making it run rich? I heard on the 2JZ the return line from the FPR causes a bottleneck as it can't return the fuel to the tank. Cant handle the increased flow.
