A friend of a friend of mine has insisted that the engine wont idle correctly without an exhaust. The headers are on and the oxy sensors are plugged in, will it make any difference?
Setting up the throttle sensor now, though it's a little confusing.
It says:
This is with 0.4mm feeler gauge inserted. Then the table below says you need continuity at 0.4mm. Itis contradicting itself there.
It says:
Gradually turn the throttle position sensor clockwise
until an ohmmeter resistance is gone, then secure the
sensor with two screws.until an ohmmeter resistance is gone, then secure the
