Just took my swap for a test drive last night.
1uz (40/40/40) with A341E that I pulled from a junk yard last week from a 92 SC400. Unfortunately, there were no signs of serious accident on the vehicle, so why it was relinquished to a junk yard, I do not know. It was delivered to the yard just a few days before I stripped it, so I think injectors will still be fine, and all seem to sound good, but was unable to check cold start inj. yet.
Engine harness is unmolested, and connectors from the body harness clipped off and utilized.
Ignitors are grounded.
Starting is a little rough. crank - nothing. crank - sputter, crank -sputter, crank - 1 sec of running, crank - runs, give 1/8 throttle to get it moving, after about 5 seconds, I can take my foot off, and it idles super smooth.
Was not aware this was a learning computer, and I kept removing the negative battery cable thought the process. I'm sure this only magnified my problems.
I know I have an exhaust leak about 1 foot away from the main passenger o2 sensor. Also, I do not have the after cat o2's. exhaust is pretty high on the back pressure scale for right now, as it's running thru a 2" single after the transmission (stock 95 nissan pickup muffler and tail pipe).
Test drive. Reverse was smooth, back out of drive way. Shift (stock SC4 shifter with no wires connected to it) into forward easily, and immediately remember I need to hook up the power steering asap.
Auto shift at about 2500, seems a little sluggish. Stop sign, turn right, shift into 1, and again it auto shifts about 2500 on it's own, so I just move it back to D, and leave it alone. Give it about 40% throttle, I feel like the engine knows I want it to accelerate, but acts like a 4 year old being told to go to bed. I know i have to, but I'm going to drag it out as long as possible.
Hit about 45mph, shifts into 3 and O/D all on it's own. Pattern basically repeats. I would guess running a 1/4 mile, I could hit about 60 or so. This is in a 2200lb mini pickup. It should be MUCH snappier (the 2.4l in it was).
Fuel pressure is on high pressure all the time (direct wired fuel pump).
I am assuming it's in limp mode, and certainly needs to "learn" before a full evaluation. Is this something the secondary o2's missing could cause? Leaking cold start (will restart immediately if you shut off, and try again, but wait 2 min, and it is hard to start again).
Anything else stand out as being wrong?
