LS400 sluggishness questions
Can someone tell me which OBD applies to the '95 LS, is it the OBDI or OBDII diagnostic tool? In addition, is it possible that something as simple as a clogged fuel filter be the culprit? My only problem is slow acceloration at take off and midrange acceleration. A clogged fuel filter could be restricting the fuel flow under acceleration, I've done everything else accept replace the fuel filter. Any thoughts and suggestions? One more thing, where can I get a reasonably priced OBD tool, and what's with the SAFC?? Should I be looking to acquire one these as well? Thanks much.
LS400GUY
Och:
please let us know if and when you install the SAFC-II, I'm having the same problem as you with the sluggishness, and I've done most of everything you've done with my '95 LS400, I only have 123k miles and bought it a year ago w/107k miles but the previous owner never changed the air filter (it was "disgustingly" dirty). I'd immediately changed tb & related bearings, wp, tenioner, cam & crank seals, plugs(repl. w/iridium), wires, caps/rotors, tranny flush repl w/Amsoil 100 syn oil, use ONLY Castrol Syntec motor oil, and I'm a big believer in Marvel mystery oil in the crankcase and gas., repl both primary o2 sensors. While the pickup is drastically improved after all of this, I still think it should have much quicker p/u with 260 horses pushing it. Huge difference in p/u from my '98 LS400, of course that one has VVTI. Should my attn be centered on the MAF? I truly believe with it running with a dirty and clogged air filter for maybe 50k miles or more is contributing to the sluggishness and high idle speed upon start-up (high idle goes to normal after a few minutes). If anyone else can offer suggestions, it would be greatly appreciated. Cheers.
LS400GUY
LS400GUY
