Welp, my timing belt and water pump replacement didn't do jack, except my water pump no longer leaks so the car doesn't overheat. It still pings and lags.
White LS, if you can be a little more specific about the cable, (I assume it's the throttle cable), and how exactly did you tighten it, I will try it on my car, and see if it does anything. However, I think if tightening cable does anything, it probably has to do with faulty TPS.
I'm probably going to try and hook up SAFC controller, and try playing with air/fuel ratios, and see if it improves anything. But thats not until a couple of month from now.
