Excessive heat is a sign of a little too rich and retarded timing.. Especially if pipes are glowing on light cruise..
Ceramic coating hot parts and some carefully placed heat shields helps big time..
An old stainless steel saucepan cut and drilled just right makes a VERY good heat shield around turbine housing.. Google pan heat shield..
http://www.supraforums.com/forum/showthread.php?326366-DIY-Turbo-Heat-Shield-write-up-with-pics.
If want to go one step further ?? There's some alloy heat shield out there which can be pop riveted using s/ steel rivets to hold this alloy / fibre glass on the inside of pot shield.. I don't like turbo dipper covers much!!
They hold too much heat in...
HTH...
